Introducción
If the LCD screen is damaged or broken, you may want to remove it and repair or replace it.
Qué necesitas
Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
One 6.25 mm screw is located on the top right corner, right to the "OK" button.
Four 4.45 mm screws are on the bottom of the camera.
Two 2.95 mm screws are on the left side of the camera, above the USB port.
Flip up the LCD screen to reveal the two orange ribbon cables.
Disconnect the two ribbons cables from their sockets on the motherboard.
Una persona más ha completado esta guía.
