Introducción
How to remove the buttons.
Partes
No se requieren partes.
Position the camera with the bottom facing up. With your finger, slide the battery cover in the direction of open arrow. The battery cover will spring open, so be careful to lift it up gently.
  • Position the camera with the bottom facing up.
  • With your finger, slide the battery cover in the direction of open arrow.
  • The battery cover will spring open, so be careful to lift it up gently.
Agregar Comentario
Use a Phillips #00 screwdriver to remove the seven 4.5mm screws. There are 2 on the left There are 2 on the right
  • Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
    • There are 2 on the left
    • There are 2 on the right
    • There are 3 on the bottom
Agregar Comentario
Firmly grasp and pull back casing off. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off.
  • Firmly grasp and pull back casing off.
Agregar Comentario
Use #00 screwdriver to pry off buttons. Use #00 screwdriver to pry off buttons. Use #00 screwdriver to pry off buttons.
  • Use #00 screwdriver to pry off buttons.
Agregar Comentario
Conclusión
Alan Galarza
Miembro Desde 03/10/10
69 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-51, Amido Fall 2010 Miembro de Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Miembros
7 Guías creadas
Thank you this was very helpful!
carolnelson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 1,167
