Introducción
Use this guide to remove the back case.
Partes
No se requieren partes.
Position the camera with the bottom facing up. With your finger, slide the battery cover in the direction of open arrow. The battery cover will spring open, so be careful to lift it up gently.
  • Position the camera with the bottom facing up.
  • With your finger, slide the battery cover in the direction of open arrow.
  • The battery cover will spring open, so be careful to lift it up gently.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a Phillips #00 screwdriver to remove the seven 4.5mm screws. There are 2 on the left There are 2 on the right
  • Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
    • There are 2 on the left
    • There are 2 on the right
    • There are 3 on the bottom
Agregar Comentario
Firmly grasp and pull back casing off. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off.
  • Firmly grasp and pull back casing off.
Agregar Comentario
Conclusión
Dustin Rodgers
Miembro Desde 05/10/10
50 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-51, Amido Fall 2010 Miembro de Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 2
Todo El Tiempo: 1,380
