Introducción
Removing and replacing the LCD and LCD casing.
Partes
No se requieren partes.
Use your finger tip to slide battery cover door away from the center of the camera.
  • Use your finger tip to slide battery cover door away from the center of the camera.
  • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Agregar Comentario
Remove the old batteries.
  • Remove the old batteries.
Agregar Comentario
Remove 7 screws from the outer case with a Phillips #00. All screws are 4.45mm. There are 2 screws on the port side.
  • Remove 7 screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
Agregar Comentario
Make sure the battery cap is "up". Pull the outer case off with your hands. Pull the outer case off with your hands.
  • Make sure the battery cap is "up".
  • Pull the outer case off with your hands.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
The LCD Screen is hinged at the bottom.
  • The LCD Screen is hinged at the bottom.
  • Put your thumb in the upper right corner of the LCD Screen.
    • Pull the LCD screen out of it's outer case with your thumb.
Agregar Comentario
Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
Agregar Comentario
Desolder the two points. One on the port side.
  • Desolder the two points.
    • One on the port side.
    • One on the bottom.
Agregar Comentario
After desoldering the LCD casing, just use your fingers to carefully remove it.
  • After desoldering the LCD casing, just use your fingers to carefully remove it.
Agregar Comentario
Flip up the black tab on the bottom of the LCD Screen with a fingertip.
  • Flip up the black tab on the bottom of the LCD Screen with a fingertip.
Agregar Comentario
Remove the LCD ribbon cable from inside the black tab.
  • Remove the LCD ribbon cable from inside the black tab.
Agregar Comentario
Conclusión
6 personas más completaron esta guía.
Taggart Ashby
Miembro Desde 15/04/10
291 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 26-19, Regan Spring 2010 Miembro de Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Miembros
7 Guías creadas
Thank you... i fixed my old camera lcd.
anthoxman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 11
Todo El Tiempo: 4,671
