Introducción
Replacing the capacitor.
Use your finger tip to slide battery cover door away from the center of the camera.
  • Use your finger tip to slide battery cover door away from the center of the camera.
  • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Agregar Comentario
Remove the old batteries.
  • Remove the old batteries.
Agregar Comentario
Remove 7 screws from the outer case with a Phillips #00. All screws are 4.45mm. There are 2 screws on the port side.
  • Remove 7 screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
Agregar Comentario
Make sure the battery cap is "up". Pull the outer case off with your hands. Pull the outer case off with your hands.
  • Make sure the battery cap is "up".
  • Pull the outer case off with your hands.
Agregar Comentario
To avoid an electric shock, do not to touch capacitor. The capacitor is located underneath the lens.
  • To avoid an electric shock, do not to touch capacitor.
  • The capacitor is located underneath the lens.
  • It is held in place by 4 plastic snaps; it can be easily removed by pulling outward with your fingers.
Agregar Comentario
Desolder points connecting capacitor to circuit board.
  • Desolder points connecting capacitor to circuit board.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 26-19, Regan Spring 2010 Miembro de Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 4
Todo El Tiempo: 3,810
