Saltar al contenido principal
KitchenAid Professional 600 Speed Selector Replacement
Qué necesitas
  1. KitchenAid Professional 600 Speed Selector Replacement, Top Cover: paso 1, imagen 1 de 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Speed Selector Replacement: paso 2, imagen 1 de 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Speed Selector Replacement: paso 3, imagen 1 de 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Speed Selector Replacement, Speed Selector: paso 4, imagen 1 de 1
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
  5. KitchenAid Professional 600 Speed Selector Replacement: paso 5, imagen 1 de 3 KitchenAid Professional 600 Speed Selector Replacement: paso 5, imagen 2 de 3 KitchenAid Professional 600 Speed Selector Replacement: paso 5, imagen 3 de 3
    • Unplug the cords attached the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
  6. KitchenAid Professional 600 Speed Selector Replacement: paso 6, imagen 1 de 1
    • Pull out the Selector Switch.
Conclusión
4 personas más completaron esta guía.
Tallon Dotinga
Miembro Desde 04/11/16
487 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 25-4, Maness Spring 2016 Miembro de Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 Miembros
18 Guías creadas
7 comentarios
The instructions are to unplug the cords from the motor but the removed selector switch pictured shows the cords were removed from the selector switch. Is there a way to remove the cords from the selector switch without breaking them? donmilo@yahoo.com
Don Singleton - Contestar
The replacement part looks like a major part in the mixer and probably costs a bundle like most replacement parts… sometimes deems the replacement “not worthy” to repair!
It’s like a car that cost $25K but, all its parts if you buy them separately, it will cost you $150K !!!
david almogi - Contestar
The speed selector MSRP is $89.99 and can be found on places like eBay for $35-60. For only needing some simple tools and a little time, this fix saves you from the cost of buying a new one. These are designed to be repaired/refurbished.
Rachel Johnson -
When the speed selector is replaced, what is the rpm for “stir”?
everything is working, but it still seems too fast at 120rpm and I can’t see a difference between speeds 6, 8, & 10.
Jessica - Contestar
The advice about kitchenaid600 switch was good. The form to get me able to say thanks was not.
What thehelldoyouwant - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 23
Ultimos 30 días: 144
Todo El Tiempo: 10,387
