Saltar al contenido principal
Kindle Fire HDX 7" Microphone Replacement
Qué necesitas
  1. Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: paso 1, imagen 1 de 3 Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: paso 1, imagen 2 de 3 Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: paso 1, imagen 3 de 3
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Microphone Replacement, Rear Panel: paso 3, imagen 1 de 1
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Microphone Replacement: paso 4, imagen 1 de 2 Kindle Fire HDX 7" Microphone Replacement: paso 4, imagen 2 de 2
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Microphone Replacement: paso 5, imagen 1 de 1
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Microphone Replacement, Microphone: paso 7, imagen 1 de 2 Kindle Fire HDX 7" Microphone Replacement, Microphone: paso 7, imagen 2 de 2
    • Pry up the left speaker with the flat end of a spudger and remove.
  7. Kindle Fire HDX 7" Microphone Replacement: paso 8, imagen 1 de 2 Kindle Fire HDX 7" Microphone Replacement: paso 8, imagen 2 de 2
    • Pry up the right speaker with the flat end of a spudger and remove.
  8. Kindle Fire HDX 7" Microphone Replacement: paso 9, imagen 1 de 3 Kindle Fire HDX 7" Microphone Replacement: paso 9, imagen 2 de 3 Kindle Fire HDX 7" Microphone Replacement: paso 9, imagen 3 de 3
    • Pry up the microphone connector from the rear panel with the flat end of a spudger.
    • Pull up on the microphone with a pair of tweezers to remove.
Conclusión
2 personas más completaron esta guía.
Blake Klein
Miembro Desde 01/29/17
70,568 Reputación
50 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 612
