Saltar al contenido principal
Kindle 2 Wireless Card Replacement
Qué necesitas
  1. Kindle 2 Wireless Card Replacement, Battery: paso 1, imagen 1 de 3 Kindle 2 Wireless Card Replacement, Battery: paso 1, imagen 2 de 3 Kindle 2 Wireless Card Replacement, Battery: paso 1, imagen 3 de 3
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
  2. Kindle 2 Wireless Card Replacement: paso 2, imagen 1 de 2 Kindle 2 Wireless Card Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
  3. Kindle 2 Wireless Card Replacement: paso 3, imagen 1 de 2 Kindle 2 Wireless Card Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
  4. Kindle 2 Wireless Card Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
  5. Kindle 2 Wireless Card Replacement: paso 5, imagen 1 de 2 Kindle 2 Wireless Card Replacement: paso 5, imagen 2 de 2
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
  6. Kindle 2 Wireless Card Replacement, Wireless Card: paso 6, imagen 1 de 1
    • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
    • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
  7. Kindle 2 Wireless Card Replacement: paso 7, imagen 1 de 1
    • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
  8. Kindle 2 Wireless Card Replacement: paso 8, imagen 1 de 2 Kindle 2 Wireless Card Replacement: paso 8, imagen 2 de 2
    • Use your fingers to lift the left end of the wireless card.
    • Pull the card out of the slot.
Conclusión
Una persona más ha completado esta guía.
Dayna Scott
Miembro Desde 04/16/13
955 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-32, Amido Spring 2013 Miembro de Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 23
Todo El Tiempo: 1,653
