Saltar al contenido principal
Kindle 2 Motherboard Replacement
Qué necesitas
  1. Kindle 2 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Kindle 2 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Kindle 2 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
  2. Kindle 2 Motherboard Replacement: paso 2, imagen 1 de 2 Kindle 2 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
  3. Kindle 2 Motherboard Replacement: paso 3, imagen 1 de 2 Kindle 2 Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
  4. Kindle 2 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
  5. Kindle 2 Motherboard Replacement: paso 5, imagen 1 de 2 Kindle 2 Motherboard Replacement: paso 5, imagen 2 de 2
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
  6. Kindle 2 Motherboard Replacement, Wireless Card: paso 6, imagen 1 de 1
    • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
    • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
  7. Kindle 2 Motherboard Replacement: paso 7, imagen 1 de 1
    • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
  8. Kindle 2 Motherboard Replacement: paso 8, imagen 1 de 2 Kindle 2 Motherboard Replacement: paso 8, imagen 2 de 2
    • Use your fingers to lift the left end of the wireless card.
    • Pull the card out of the slot.
  9. Kindle 2 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 2 Kindle 2 Motherboard Replacement, Motherboard: paso 9, imagen 2 de 2
    • Remove 16 screws from the midframe.
  10. Kindle 2 Motherboard Replacement: paso 10, imagen 1 de 3 Kindle 2 Motherboard Replacement: paso 10, imagen 2 de 3 Kindle 2 Motherboard Replacement: paso 10, imagen 3 de 3
    • Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire.
    • Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
  11. Kindle 2 Motherboard Replacement: paso 11, imagen 1 de 3 Kindle 2 Motherboard Replacement: paso 11, imagen 2 de 3 Kindle 2 Motherboard Replacement: paso 11, imagen 3 de 3
    • Wedge the opening tool underneath the plastic ribbon and gently pull up to lift the brown connector flap.
    • Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it.
  12. Kindle 2 Motherboard Replacement: paso 12, imagen 1 de 1
    • Locate the next brown connector three inches to the right of the previous connector and repeat Step 10 to remove the plastic ribbon.
  13. Kindle 2 Motherboard Replacement: paso 13, imagen 1 de 2 Kindle 2 Motherboard Replacement: paso 13, imagen 2 de 2
    • Rotate the device 180 degrees and locate a smaller brown connector on the left side of the device.
    • Repeat Step 10.
  14. Kindle 2 Motherboard Replacement: paso 14, imagen 1 de 1
    • Push your finger down on the last plastic ribbon.
    • Slide your finger away from the connector to remove the last ribbon.
  15. Kindle 2 Motherboard Replacement: paso 15, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the motherboard located around the LAB126 logo.
  16. Kindle 2 Motherboard Replacement: paso 16, imagen 1 de 1
    • Grab the bottom corner of the motherboard and safely remove it from the Kindle.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 12-32, Amido Spring 2013 Miembro de Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 18
Todo El Tiempo: 2,107
