Saltar al contenido principal
Kenmore 110 Series Washing Machine Electronic Control Replacement
Qué necesitas
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: paso 1, imagen 1 de 1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: paso 2, imagen 1 de 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: paso 2, imagen 2 de 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: paso 2, imagen 3 de 3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: paso 3, imagen 1 de 2 Kenmore 110 Series Washing Machine Electronic Control Replacement: paso 3, imagen 2 de 2
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
Conclusión
10 personas más completaron esta guía.
Robert Trout
Miembro Desde 09/26/12
1,234 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 15-43, Forte Fall 2012 Miembro de Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Miembros
11 Guías creadas
3 comentarios
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - Contestar
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 57
Ultimos 30 días: 143
Todo El Tiempo: 27,581
