Introducción
This guide details the steps to take off the button pad of your Inter-tel IP 8660.
Partes
No se requieren partes.
Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
Agregar Comentario
Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out. 8 mm long 11 mm long
  • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
Agregar Comentario
Lift up the back cover and set it aside.
  • Lift up the back cover and set it aside.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
Agregar Comentario
Lift up the speaker.
  • Lift up the speaker.
Agregar Comentario
Lift up the motherboard and set aside
  • Lift up the motherboard and set aside
Agregar Comentario
Peel off all rubber button covers.
  • Peel off all rubber button covers.
Agregar Comentario
Remove all plastic buttons.  (Note: Look at the initial picture for locations of each button set)
  • Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 11-24, Maness Winter 2012 Miembro de Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 661
