Saltar al contenido principal
Insignia NS-HD01A Battery Replacement
Qué necesitas
  1. Insignia NS-HD01A Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the rubber screw caps using the pointed tip of the Spudger.
  2. Insignia NS-HD01A Battery Replacement: paso 2, imagen 1 de 1
    • Remove the four 6.0 mm Phillips screws located below the rubber caps using the PH00 bit installed in the driver.
  3. Insignia NS-HD01A Battery Replacement: paso 3, imagen 1 de 2 Insignia NS-HD01A Battery Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to pry open the back cover.
    • Slide the tool around the sides of the radio to gradually pry the back cover off. Do not remove the cover completely as there is still a cable connecting it to radio.
  4. Insignia NS-HD01A Battery Replacement: paso 4, imagen 1 de 3 Insignia NS-HD01A Battery Replacement: paso 4, imagen 2 de 3 Insignia NS-HD01A Battery Replacement: paso 4, imagen 3 de 3
    • Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides.
  5. Insignia NS-HD01A Battery Replacement: paso 5, imagen 1 de 2 Insignia NS-HD01A Battery Replacement: paso 5, imagen 2 de 2
    • Use the flat side of the Spudger to pry the battery out of the back cover.
    • Insert the replacement battery into the back cover.
    • Reassemble the radio, making sure to reconnect the battery cable.
Conclusión
2 personas más completaron esta guía.
Joel Najmon
Miembro Desde 10/08/16
152 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-2, Wilson Fall 2016 Miembro de IUPUI, Team 2-2, Wilson Fall 2016
IUPUI-WILSON-F16S2G2
5 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,022
