Saltar al contenido principal
IBM ThinkPad T42 RAM Replacement
Qué necesitas
  1. IBM ThinkPad T42 RAM Replacement, Battery Clips: paso 1, imagen 1 de 1
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 RAM Replacement, Removing the Battery: paso 2, imagen 1 de 1
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Unscrew the pictured screwed holding the memory cover in place.
  4. IBM ThinkPad T42 RAM Replacement: paso 4, imagen 1 de 1
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
    • Pull the stick out carefully.
    • In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
Conclusión
7 personas más completaron esta guía.
Kevin Rehm
Miembro Desde 04/19/10
472 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 29-76, Johann Spring 2010 Miembro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Miembros
35 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 23
Todo El Tiempo: 7,084
