Saltar al contenido principal
IBM ThinkPad T42 Mini-PCI Port Replacement
Qué necesitas
  1. IBM ThinkPad T42 Mini-PCI Port Replacement, Bottom cover: paso 1, imagen 1 de 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Mini-PCI Port Replacement, Rear screws: paso 2, imagen 1 de 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Mini-PCI Port Replacement, Keyboard and Trackpad: paso 3, imagen 1 de 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Mini-PCI Port Replacement: paso 4, imagen 1 de 2 IBM ThinkPad T42 Mini-PCI Port Replacement: paso 4, imagen 2 de 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Bracket: paso 5, imagen 1 de 1
    • Remove the screw affixing the bracket down.
  6. IBM ThinkPad T42 Mini-PCI Port Replacement, Bracket Removal: paso 6, imagen 1 de 1
    • Lift the bracket up and out.
  7. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Removal: paso 7, imagen 1 de 1
    • Carefully disconnect it from the motherboard and pull it out of the device.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 29-76, Johann Spring 2010 Miembro de Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Miembros
35 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 22
Todo El Tiempo: 4,413
