Saltar al contenido principal
IBM ThinkPad T30 Optical Drive Replacement
Qué necesitas
  1. IBM ThinkPad T30 Optical Drive Replacement, Battery: paso 1, imagen 1 de 3 IBM ThinkPad T30 Optical Drive Replacement, Battery: paso 1, imagen 2 de 3 IBM ThinkPad T30 Optical Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Optical Drive Replacement, Optical Drive: paso 2, imagen 1 de 1
    • Locate the 4.8mm Phillips #0 screw on the far left of the ThinkPad, closest to the edge and above the battery, and unscrew it with a Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Optical Drive Replacement: paso 3, imagen 1 de 2 IBM ThinkPad T30 Optical Drive Replacement: paso 3, imagen 2 de 2
    • On the side of the ThinkPad, locate a lock next to the optical drive. Use your fingernail to slide the lock to the right.
  4. IBM ThinkPad T30 Optical Drive Replacement: paso 4, imagen 1 de 2 IBM ThinkPad T30 Optical Drive Replacement: paso 4, imagen 2 de 2
    • Once it is unlocked, a small tab will pop out. Pull on the tab with your fingers.
    • The optical drive will easily slide out. Remove the optical drive.
Conclusión
Una persona más ha completado esta guía.
Alex Kost
Miembro Desde 10/05/12
271 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-20, Amido Fall 2012 Miembro de Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 1,893
