Introducción
Use this guide to replace your hard drive.
Partes
No se requieren partes.
Make sure the ThinkPad is off and the power supply is unplugged. Flip the ThinkPad upside down with the bottom facing you. Slide the latch on the underside of the ThinkPad to the right into the unlock position.
  • Make sure the ThinkPad is off and the power supply is unplugged.
  • Flip the ThinkPad upside down with the bottom facing you.
  • Slide the latch on the underside of the ThinkPad to the right into the unlock position.
  • While holding the latch in the unlock position, lift the battery out with your other hand.
Agregar Comentario
Flip to the back of the Thinkpad and focus on the screw in the bottom left corner of the Thinkpad.
  • Flip to the back of the Thinkpad and focus on the screw in the bottom left corner of the Thinkpad.
  • Unscrew the 11mm Phillips #0 screw with a Phillips #0 screwdriver.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Flip the Thinkpad on its side to get a better view of the hard drive. Use your thumbs to push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad. Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
  • Flip the Thinkpad on its side to get a better view of the hard drive.
  • Use your thumbs to push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
  • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
Agregar Comentario
Use the plastic opening tool to remove the black plastic cover from the main body of the hard drive. Pry on the ends of the plastic cover to detach it from the hard drive. Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
  • Use the plastic opening tool to remove the black plastic cover from the main body of the hard drive. Pry on the ends of the plastic cover to detach it from the hard drive.
  • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
Agregar Comentario
Locate and remove the four 2.8mm Phillips #0 screws on the mounting bracket. Pull the mounting bracket off of the hard drive.
  • Locate and remove the four 2.8mm Phillips #0 screws on the mounting bracket.
  • Pull the mounting bracket off of the hard drive.
  • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
Agregar Comentario
Conclusión
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
7 personas más completaron esta guía.
Allie Knauer
Miembro Desde 05/10/12
54 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-20, Amido Fall 2012 Miembro de Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Miembros
16 Guías creadas
good description and photos..thanks :]
David - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 26
Últimos 30 Días: 104
Todo El Tiempo: 12,319
