Flip the ThinkPad over so that it is upside down. Slide the highlighted tab to the left.
  • Flip the ThinkPad over so that it is upside down.
  • Slide the highlighted tab to the left.
  • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Agregar Comentario
Remove the two 5.3mm cover screws. Gently lift the cover containing the RAM.
  • Remove the two 5.3mm cover screws.
  • Gently lift the cover containing the RAM.
Agregar Comentario
Remove RAM module by pressing the two metal pieces outward with your thumbs.
  • Remove RAM module by pressing the two metal pieces outward with your thumbs.
Agregar Comentario
Lift the RAM module up and out, away from the yellow connector. Place the RAM module away from any magnets or static electricity prone areas.
  • Lift the RAM module up and out, away from the yellow connector.
  • Place the RAM module away from any magnets or static electricity prone areas.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jessica
Miembro Desde 06/10/10
159 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 4-44, Amido Fall 2010 Miembro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Miembros
26 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 2,716
