Introducción
Unlike most tablets, the Huawei MediaPad M2 10.0 has a display assembly that is easy to remove, a big positive when looking at repair. The battery is incredibly difficult to remove, however, giving the tablet a 7 out of 10 on the repairability scale.
Front/back reference shots. Front/back reference shots. Front/back reference shots.
  • Front/back reference shots.
Agregar Comentario
Simple plastic clips make opening easy. The display cable has enough slack to lay the display aside to work on the interior.
  • Simple plastic clips make opening easy.
  • The display cable has enough slack to lay the display aside to work on the interior.
Agregar Comentario
Display assembly carries: display interconnect cable, home button/fingerprint reader and cable, and its bracket.
  • Display assembly carries: display interconnect cable, home button/fingerprint reader and cable, and its bracket.
    • Home button/fingerprint reader is easily removed and replaced.
Agregar Comentario
The battery is glued to the rear case by very strong adhesive. Heat, adhesive removal fluid, and much prying, the battery is removed.
  • The battery is glued to the rear case by very strong adhesive.
  • Heat, adhesive removal fluid, and much prying, the battery is removed.
    • Frustrating that an inevitable repair/replacement would be this hard, but at least it isn't blocking other components' replacement.
Agregar Comentario
The bracket over the speaker and button/headphone jack cable has two different kinds of screws, Torx and Phillips, making removal obnoxious. Removable in parallel with the battery are: lower speaker, speaker/antennas, brackets, and microphone bumper.
  • The bracket over the speaker and button/headphone jack cable has two different kinds of screws, Torx and Phillips, making removal obnoxious.
  • Removable in parallel with the battery are: lower speaker, speaker/antennas, brackets, and microphone bumper.
    • SIM tray can be removed while the device is sealed, obviously.
Agregar Comentario
The final components out of the rear case are fairly modular:
  • The final components out of the rear case are fairly modular:
    • SIM reader and vibrator assembly
    • Headphone jack and button cable assembly
    • Front and rear facing cameras
    • Motherboard, unfortunately has a soldered-on charging port. That means a more expensive repair for a common failure point.
Agregar Comentario
The Huawei MediaPad M2 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair): The display is easily removed from the simple clips holding it to the body, simplifying repairs.
  • The Huawei MediaPad M2 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • The display is easily removed from the simple clips holding it to the body, simplifying repairs.
    • Most components are modular and not overly complex.
    • The battery is extremely difficult to remove, even with heat and prying.
    • The charging port is soldered to the motherboard, making replacement of this high-use component expensive.
    • Manufacturer does not provide user-accessible repair documentation.
Agregar Comentario
Linea de Meta
Una persona más ha completado esta guía.
Andrew Optimus Goldberg
Miembro Desde 17/10/09
368,639 Reputación
1,264 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
116 Miembros
5,774 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 45
Últimos 30 Días: 235
Todo El Tiempo: 2,016
