Saltar al contenido principal
How to fix an iPhone 4S that won't turn on or charge
Qué necesitas
  1. How to fix an iPhone 4S that won't turn on or charge, Do a forced restart: paso 1, imagen 1 de 2 How to fix an iPhone 4S that won't turn on or charge, Do a forced restart: paso 1, imagen 2 de 2
    • Press and hold the Power and Home buttons for 10 seconds.
    • Wait for about 10 seconds. If you don't see the Apple logo, continue to the next step.
  2. How to fix an iPhone 4S that won't turn on or charge, Charge the iPhone: paso 2, imagen 1 de 1
    • Try charging the phone for at least 20 minutes.
    • You may also want to try using a different charger if you have one.
    • If this doesn't work, continue to the next step
  3. How to fix an iPhone 4S that won't turn on or charge, See if iTunes recognizes the iPhone: paso 3, imagen 1 de 2 How to fix an iPhone 4S that won't turn on or charge, See if iTunes recognizes the iPhone: paso 3, imagen 2 de 2
    • Try connecting the iPhone to a Windows or Mac computer and launch iTunes (If you don't have iTunes, you can download it at http://itunes.com/download) If you don't see an iPhone icon in the toolbar at the top left, continue to step 5
    • On macOS Catalina 10.15 or newer, go to the next step
  4. How to fix an iPhone 4S that won't turn on or charge, Hold home button while plugging in the charger: paso 4, imagen 1 de 2 How to fix an iPhone 4S that won't turn on or charge, Hold home button while plugging in the charger: paso 4, imagen 2 de 2
    • Allow the iPhone to charge for a while
    • Then hold down on the home button while plugging in the 30-Pin connector.
  5. How to fix an iPhone 4S that won't turn on or charge, Restore the iPhone: paso 5, imagen 1 de 2 How to fix an iPhone 4S that won't turn on or charge, Restore the iPhone: paso 5, imagen 2 de 2
    • If the previous step worked but you still can't see anything on the iPhone's screen, you may want to restore the iPhone.
    • THIS WILL ERASE ALL THE DATA ON THE iPHONE!
    • Connect the iPhone to a Windows or Mac computer and open iTunes, click the iPhone icon in the toolbar at the top left.
    • Click the "Restore iPhone" button at the top right to restore the iPhone.
  6. How to fix an iPhone 4S that won't turn on or charge, Instructions for macOS 10.15 and newer: paso 6, imagen 1 de 3 How to fix an iPhone 4S that won't turn on or charge, Instructions for macOS 10.15 and newer: paso 6, imagen 2 de 3 How to fix an iPhone 4S that won't turn on or charge, Instructions for macOS 10.15 and newer: paso 6, imagen 3 de 3
    • Hold the control key while clicking on the Finder icon and select "New Finder Window"
    • In the Sidebar, look for the iPhone under "Locations", if you see the iPhone, select it.
    • You may be prompted to trust the iPhone to the computer.
    • If you don't see the iPhone then go to the next step.
Conclusión
If you fixed it then CONGRATS! If you didn't fix it then, You may want to consider replacing the screen on the iPhone.
9 personas más completaron esta guía.
Elijah
Miembro Desde 12/16/18
1,070 Reputación
2 Guías creadas
Un comentario
So if I replace the screen, it will fix a stuck power button?
Edvard Ulven Refsdal - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 17
Ultimos 7 días: 67
Ultimos 30 días: 377
Todo El Tiempo: 12,420
