Introducción
Outline what you are going to teach someone how to do.
Unscrew the four Torx screws from the backplate.
  • Unscrew the four Torx screws from the backplate.
  • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
  • The screws are T5 Torx screws, 5.6mm.
Agregar Comentario
Swivel the phone open.
  • Swivel the phone open.
Agregar Comentario
Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
  • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
  • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Remove the two Torx screws from below the cover.
  • Remove the two Torx screws from below the cover.
  • These are T5 Torx screws, 8.6mm.
Agregar Comentario
Gently work a spudger or a fingernail between the keypad face and the backplate.
  • Gently work a spudger or a fingernail between the keypad face and the backplate.
  • The pieces are clipped together most tightly at the bottom loop section.
Agregar Comentario
Separate the keypad face from the backplate. The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
  • Separate the keypad face from the backplate.
  • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
  • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
Agregar Comentario
Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly. Note that only the bottom strut has a tab. The screws are Phillips, 2.9mm
  • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
  • Note that only the bottom strut has a tab.
  • The screws are Phillips, 2.9mm
Agregar Comentario
The back housing is now disassembled, and the swivel assembly is revealed.
  • The back housing is now disassembled, and the swivel assembly is revealed.
Agregar Comentario
Tighten the four small Phillips screws.
  • Tighten the four small Phillips screws.
  • The swivel assembly should now be less wobbly and loose, improving the function of the phone.
  • The screws are Phillips, 2.4mm.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Beau Blanchard
Miembro Desde 30/09/12
20 Reputación
12 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 424
