Partes
No se requieren partes.
To open the crumb tray, pinch the lever in the photo. If the lever does not keep the the crumb tray closed, stretch the lever so that to make sure the two horizontal pieces are aligned.
  • To open the crumb tray, pinch the lever in the photo.
  • If the lever does not keep the the crumb tray closed, stretch the lever so that to make sure the two horizontal pieces are aligned.
Agregar Comentario
Now that the tray is exposed, it is possible to clean the face here.
  • Now that the tray is exposed, it is possible to clean the face here.
  • Try to not let water get into the toaster as this may damage the heating coil.
  • If the tray can not be cleaned simply by opening it, keep going through the guide to fully remove it.
Agregar Comentario
To remove the tray, the metal hinges must be bent up. While applying pressure to the bottom of the toaster, use pliers or tweezers to bend up the bracket. The pressure applied to the bottom of the toaster should be just enough to allow the bracket to swing up. Remove the tray and clean.
  • To remove the tray, the metal hinges must be bent up.
  • While applying pressure to the bottom of the toaster, use pliers or tweezers to bend up the bracket. The pressure applied to the bottom of the toaster should be just enough to allow the bracket to swing up.
  • Remove the tray and clean.
Agregar Comentario
Conclusión
Grant Haug
Miembro Desde 26/09/12
115 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 2-8, Propen Fall 2012 Miembro de Cal Poly, Team 2-8, Propen Fall 2012
CPSU-PROPEN-F12S2G8
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 15
Todo El Tiempo: 1,601
