Introducción
Metals used in circuits can react with oxygen. It's a common and natural reaction and can cause connection problems, but the process is reversible with deoxidizing sprays which can improve the sound quality of your amplifier.
Partes
No se requieren partes.
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
Agregar Comentario
Remove the top screw on the back panel. Remove the top screw on the back panel.
  • Remove the top screw on the back panel.
Agregar Comentario
Slide off the case to expose the internal components of the receiver. Slide off the case to expose the internal components of the receiver.
  • Slide off the case to expose the internal components of the receiver.
Agregar Comentario
Carefully wipe the circuit board and its components to remove any dust.
  • Carefully wipe the circuit board and its components to remove any dust.
  • Failing to remove any dust before applying DeoxIT may cause the dust to get trapped on the components, increasing the risk of overheating.
Agregar Comentario
Lightly spray the circuit board with DeoxIT.
  • Lightly spray the circuit board with DeoxIT.
  • Take care to evenly coat the circuit board with DeoxIT. Excess liquid will dry slowly. If power is reapplied before it has completely dried, it can cause short-circuits and damage to the device.
Agregar Comentario
Lightly spray the input and output connectors with DeoxIT on the inside of the back panel. Lightly spray the input and output connectors with DeoxIT on the inside of the back panel.
  • Lightly spray the input and output connectors with DeoxIT on the inside of the back panel.
Agregar Comentario
Linea de Meta
Kevin Barton
Miembro Desde 13/04/10
89 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 27-92, Amido Spring 2010 Miembro de Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Miembros
7 Guías creadas
As an electronic repair technician I would never advise spraying deoxit on a circuit board or removing dust with a papertowel. May I suggest using a can of compressed air to remove any dust inside the unit and focusing the use of contact cleaner on potentiometers, input/output jacks, sockets/plugs etc. Cleaning the top of the circuit board will do little to nothing to improve the performance or sound of your amplifier as you will simply be cleaning the top side of components that are physically soldered to pads on the other side of the PCB.
Muham - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 12
Todo El Tiempo: 4,496
