Introducción
This guide will walk you through the steps to cleaning the Roomba air filter. A clean filter will improve performance and should be checked regularly.
Partes
No se requieren partes.
Slide out back bin by pressing the unmarked button on top of the Roomba.
  • Slide out back bin by pressing the unmarked button on top of the Roomba.
Agregar Comentario
Slide out yellow bar on particle bin to access filter
  • Slide out yellow bar on particle bin to access filter
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
This is the air filter assembly
  • This is the air filter assembly
Agregar Comentario
Pop out filter mount by prying 2 points that hold it to the rest of the assembly
  • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
Agregar Comentario
Thoroughly clean or replace the air filter.  This can be done with compressed air or by rinsing it with water.
  • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
Agregar Comentario
Reassemble the air filter assembly and slide the particle bin back into place
  • Reassemble the air filter assembly and slide the particle bin back into place
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Scott Leonard
Miembro Desde 05/10/10
439 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 20-6, Maness Fall 2010 Miembro de Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Miembros
3 Guías creadas
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 5
Todo El Tiempo: 4,564
