Introducción
All of the internal surfaces, especially the conductive metal pieces, need to be clean and well kept in order for the microphone to function at its best.
Partes
No se requieren partes.
Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it. Be careful to not pull on the collar or you may rip the wires from the faceplate. Be careful to not pull on the collar or you may rip the wires from the faceplate.
  • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
  • Be careful to not pull on the collar or you may rip the wires from the faceplate.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Create a mild cleaning solution by mixing a few drops of dish soap and water in a cup.
  • Create a mild cleaning solution by mixing a few drops of dish soap and water in a cup.
  • Using a detailing brush and the solution, gently brush the pins and inside walls of the microphone.
Agregar Comentario
Make sure connector is completely dry before soldering, failure to do so may result in permanent damage.
  • Make sure connector is completely dry before soldering, failure to do so may result in permanent damage.
  • If you have previously soldered inside the microphone, you may use a soldering iron to melt off any excess solder that may be on the pins inside the connector. Do not attempt this if you have never soldered on the microphone before.
Agregar Comentario
Conclusión
After cleaning the faceplate and reassembling the microphone, it should work at its maximum potential.
nat coll
Miembro Desde 27/09/12
366 Reputación
17 Guías creadas
Equipo
Cal Poly, Team 7-53, Forte Fall 2012 Miembro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 18
Últimos 30 Días: 80
Todo El Tiempo: 5,619
