Saltar al contenido principal
How to clean the Shure SM58 Grille
Qué necesitas
  1. How to clean the Shure SM58 Grille, Grille: paso 1, imagen 1 de 1
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. How to clean the Shure SM58 Grille: paso 2, imagen 1 de 2 How to clean the Shure SM58 Grille: paso 2, imagen 2 de 2
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
  3. How to clean the Shure SM58 Grille, How to clean the Shure SM58 Grille: paso 3, imagen 1 de 1
    • Put two drops of dish soap into a cup.
    • Add water to cup until half full.
  4. How to clean the Shure SM58 Grille: paso 4, imagen 1 de 1
    • Place the grille in the solution of soap and water.
    • Let the grille soak for half an hour.
  5. How to clean the Shure SM58 Grille: paso 5, imagen 1 de 1
    • Remove the grille from the cup and rinse it with cold water.
    • Allow the grille to air dry.
    • Make sure the grille and the foam inside it are completely dry before placing it back on the microphone.
Linea de Meta
6 personas más completaron esta guía.
nat coll
Miembro Desde 09/27/12
642 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 7-53, Forte Fall 2012 Miembro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 12,055
