Partes
No se requieren partes.
Before starting, be sure to remove the battery from the camera. See Removing the Olympus Stylus 760 Battery Guide for details.
Agregar Comentario
Remove the screw located on the right side of the camera
  • Remove the screw located on the right side of the camera
Agregar Comentario
Remove the two screws from the left side of the camera
  • Remove the two screws from the left side of the camera
Agregar Comentario
Use a small prying device to delicately separate the front casing from the back.
New line.
  • Use a small prying device to delicately separate the front casing from the back.
New line.
    • When separating the 2 cases be cautious of the silver band and buttons that located in the middle of the camera. They will come loose.
Agregar Comentario
Remove the 2 screws on the right side of the camera. Remove the 2 screwson the left side of the camera CAUTION! Circuit ribbon is attached at the top left of the camera be careful when separating the front and back of the camera after removing the 4 screws.
  • Remove the 2 screws on the right side of the camera.
  • Remove the 2 screwson the left side of the camera
  • CAUTION! Circuit ribbon is attached at the top left of the camera be careful when separating the front and back of the camera after removing the 4 screws.
Agregar Comentario
Carefully flip up the clip attaching the ribbon from the rear to the front and pull it out
  • Carefully flip up the clip attaching the ribbon from the rear to the front and pull it out
Agregar Comentario
Carefully separate the front and back of the camera
  • Carefully separate the front and back of the camera
Agregar Comentario
You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
Agregar Comentario
Using a size 0 Phillips head, remove 3 screws holding the ribbon cable that covers the back of the lens.
  • Using a size 0 Phillips head, remove 3 screws holding the ribbon cable that covers the back of the lens.
  • CAUTION: small loose pieces under the back lens cover
Agregar Comentario
Using tweezers remove tiny square lens cases.  There are 4 small pieces.
  • Using tweezers remove tiny square lens cases. There are 4 small pieces.
  • The pieces are relatively small, so becareful that they do not fall inside of the lens.
Agregar Comentario
Remove the larger black rubber frame. Clean with condensed air.
  • Remove the larger black rubber frame. Clean with condensed air.
Agregar Comentario
Conclusión
Derek Guzman
Miembro Desde 10/02/12
17 Reputación
1 Guía escrita
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 18
Todo El Tiempo: 1,139
