Introducción
If your scanner is making a clicking/grinding noise and malfunctioning, chances are your calibration strip is dirty. In order to clean the calibration strip, the scanner tray and glass must be removed.
Carefully wedge the flathead 3/32" screwdriver on the outer groove of the control panel faceplate.
  • Carefully wedge the flathead 3/32" screwdriver on the outer groove of the control panel faceplate.
  • Follow the perimeter of the groove with the flathead 3/32" screwdriver making sure to gently pry and lift upward until the control panel faceplate comes off.
  • Take your time prying off the control panel faceplate. If too much pressure is applied, the control panel faceplate can break.
Agregar Comentario
Once the control panel faceplate is off, look for the Lock/Unlock tab located underneath the off button.
  • Once the control panel faceplate is off, look for the Lock/Unlock tab located underneath the off button.
  • To unlock and release the control panel, insert the flathead 3/32" screwdriver into the tab and carefully push down. The control panel will then separate from the printer's base by sliding it downward a little.
Agregar Comentario
Underneath the control panel will be a flat grey ribbon cable. This cable is  attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
  • Underneath the control panel will be a flat grey ribbon cable. This cable is attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
  • Carefully disconnect both ends of the flat grey ribbon cable to release the control panel in its entirety.
    • Only pull from the connector portion of the cable, as pulling on the wires may damage them.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Lift open the scanner lid and locate a black tab located at the center of the scanner bed.
  • Lift open the scanner lid and locate a black tab located at the center of the scanner bed.
  • Using your finger push (pull on some printers) the tab towards the scanner lid. This will release the scanner lid
Agregar Comentario
Once the scanner lid is removed use the Philips #1(Torx on some printers) Screwdriver to remove the screw. Once the scanner lid is removed use the Philips #1(Torx on some printers) Screwdriver to remove the screw.
  • Once the scanner lid is removed use the Philips #1(Torx on some printers) Screwdriver to remove the screw.
Agregar Comentario
Remove all four silver screws from the corners of the scanner glass cover with a T10 Torx Screwdriver. Organization is everything. Remember to have your iFixit Magnetic Work Mat next to you. It will help keep screws organized and in place.
  • Remove all four silver screws from the corners of the scanner glass cover with a T10 Torx Screwdriver.
  • Organization is everything. Remember to have your iFixit Magnetic Work Mat next to you. It will help keep screws organized and in place.
Agregar Comentario
Once you have removed the four torx screws, gently lift the scanner glass cover from the printer's base.
  • Once you have removed the four torx screws, gently lift the scanner glass cover from the printer's base.
Agregar Comentario
Turn the scanner glass over and place it on a clean surface.
  • Turn the scanner glass over and place it on a clean surface.
  • Moisten a lint-free cloth with alcohol and gently wipe down the calibration strip.
Agregar Comentario
Conclusión
8 personas más completaron esta guía.
Jeremy Mahrt
Miembro Desde 08/05/11
280 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-31, Maness Spring 2011 Miembro de Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 Miembros
9 Guías creadas
Thank you for this guide! My printer scan head was clicking and grinding at startup and would not allow me to print.
In addition to cleaning the glass and calibration strip, I manually slid the scanner head back and forth through its full range of motion. Once the printer was reassembled, the grinding ceased and all operations are back to normal.
FlyABus - Contestar
Yes, great advice!
And the step by step guide is really of vital help! Just taking the dust flocks out and carefully cleaning the parts w/ a small brush or ear tips and akcohol saved my 12 yr old printer! I'm soooo greatful to you all for helping us keep our hardware goods for a long time to come!
Ambriel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 8
Últimos 30 Días: 30
Todo El Tiempo: 8,587
