Introducción
Sometimes a burning smell can come form the toaster. This could be caused by crumbs stuck in the unit so its suggested that you deep clean the Black and Decker Toast R Oven.
Make sure that the toaster is unplugged before you begin.
  • Make sure that the toaster is unplugged before you begin.
  • Turn the toaster over with its backside face down.
  • Remove the two Phillips #4 1cm screws that attach the side panels.
Agregar Comentario
Pull downwards (towards the bottom of the unit) and outward to remove the side panels. Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
  • Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Agregar Comentario
Remove the metal vent piece that is below the door.
  • Remove the metal vent piece that is below the door.
  • This should slide off easily once both of the side panels are removed.
Agregar Comentario
Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
  • Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
Agregar Comentario
Remove the crumb tray (the bottom, metal panel) from the toaster unit.
  • Remove the crumb tray (the bottom, metal panel) from the toaster unit.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
  • Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
Agregar Comentario
Remove the knobs by pulling them upward; they should slide right off.
  • Remove the knobs by pulling them upward; they should slide right off.
  • When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
Agregar Comentario
Unhook the bottom of the the display panel from the toaster unit.
  • Unhook the bottom of the the display panel from the toaster unit.
  • It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
Agregar Comentario
Begin to detach the back panel from the toaster unit.
  • Begin to detach the back panel from the toaster unit.
  • Then, unhook the rest of the display panel.
  • This will also be a little tough to get off, but don't be afraid to be forceful.
Agregar Comentario
Now, you can clean the outside units of the toaster oven.
  • Now, you can clean the outside units of the toaster oven.
Agregar Comentario
Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
  • Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
Agregar Comentario
Finish removing the outside cover by lifting the lid upward.
  • Finish removing the outside cover by lifting the lid upward.
Agregar Comentario
Remove the four Phillips #4 1 cm screws from the back of the unit.
  • Remove the four Phillips #4 1 cm screws from the back of the unit.
Agregar Comentario
Conclusión
Jonathan
Miembro Desde 18/09/12
105 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 2-10, Propen Fall 2012 Miembro de Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 31
Últimos 30 Días: 138
Todo El Tiempo: 7,836
