Partes
No se requieren partes.
The Roomba Battery is the large yellow block under the Roomba's front bumper.
  • The Roomba Battery is the large yellow block under the Roomba's front bumper.
Agregar Comentario
Remove the battery by pressing the two side tabs, as demonstrated.
  • Remove the battery by pressing the two side tabs, as demonstrated.
  • Gently lift the battery up and out of the device.
Agregar Comentario
Obtain a replacement battery cell from the manufacturer. Simply drop the new battery into place.
  • Obtain a replacement battery cell from the manufacturer. Simply drop the new battery into place.
Agregar Comentario
Begin by removing the rear particle bin.
  • Begin by removing the rear particle bin.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Choose either of the two wheels on the side of the Roomba and identify the three screws located on the hubcap of the wheel.
  • Choose either of the two wheels on the side of the Roomba and identify the three screws located on the hubcap of the wheel.
Agregar Comentario
Using a Phillips Head screwdriver, remove all three screws on the side of the hubcap of the wheel.
  • Using a Phillips Head screwdriver, remove all three screws on the side of the hubcap of the wheel.
There are actually 4 screws holding the hubcap on. To get to the 4th screw, you need to loosen the top cover by removing all its screws. Note different lengths of screws.
Albert Jeans - Contestar
Gently slide the hubcap up and out of the wheel well of the Roomba.
  • Gently slide the hubcap up and out of the wheel well of the Roomba.
I have a fourth screw well up into the body on the hub cover. ~2.5cm into the body from the round hub outer circle.
Ben Carr - Contestar
Mind the wires attached to the optical encoder located in the hubcap.
  • Mind the wires attached to the optical encoder located in the hubcap.
Agregar Comentario
Using compressed air, thoroughly clean the optical encoder until satisfied.
  • Using compressed air, thoroughly clean the optical encoder until satisfied.
Agregar Comentario
With a screw driver, gently remove the drive belt from the gear.
  • With a screw driver, gently remove the drive belt from the gear.
Agregar Comentario
Carefully slide the gear out of the gear shaft of the wheel.
  • Carefully slide the gear out of the gear shaft of the wheel.
Agregar Comentario
Thoroughly clean the exposed area of the wheel using either compressed air or a moist cotton swab. Be mindful of the exposed inner drive shaft when cleaning the wheel area to prevent any preexisting dust from entering the drive shaft.
  • Thoroughly clean the exposed area of the wheel using either compressed air or a moist cotton swab. Be mindful of the exposed inner drive shaft when cleaning the wheel area to prevent any preexisting dust from entering the drive shaft.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Christian
Miembro Desde 06/10/10
263 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 20-7, Maness Fall 2010 Miembro de Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Miembros
7 Guías creadas
Thanks for your advice. I cleaned the sensors on the wheels and still the unit was having a circular dance. From another site mentioning another model there could be a problem with the sensors behind the front bumper bar and yes that was the problem. They needed blowing out with a strong air gun. Now after extensive cleaning my Roomba is running like a dream :-)
photofil - Contestar
My problem as well with my Roomba scheduler. The black and white front wheel housing was packed with rug fiber. Cleaned it out and all is well.
Also have a roomba discovery. It has a different front wheel with out any apparent sensor.
Will Long - Contestar
I have a roomba4100 it will turn on it will try to go but will stop after 1second don't know what's wrong could it be the belt
Rodney - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 21
Últimos 30 Días: 108
Todo El Tiempo: 10,739
