Introducción
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
Partes
No se requieren partes.
  • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
  • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
Agregar Comentario
Pull up on the tab to remove the batteries.
  • Pull up on the tab to remove the batteries.
  • Note: The batteries will probably fall out of their holder.
Agregar Comentario
Your camera should look something like this.
  • Your camera should look something like this.
  • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
Agregar Comentario
Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
Agregar Comentario
All cleaned up!
  • All cleaned up!
Agregar Comentario
Conclusión
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 25-26, Garner Spring 2011 Miembro de Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Miembros
6 Guías creadas
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 19
Últimos 30 Días: 98
Todo El Tiempo: 11,048
