Introducción
This guide will show the user how to open the top half of the scanner and clean the interior side of the surface glass.
Partes
No se requieren partes.
Loosen the screws on the serial port by turning them counter clockwise by hand. After loosening the screws, pull the serial port out. After loosening the screws, pull the serial port out.
  • Loosen the screws on the serial port by turning them counter clockwise by hand.
  • After loosening the screws, pull the serial port out.
Agregar Comentario
Lift lid to its vertical position. Pull lid straight up to remove it from the scanner. Pull lid straight up to remove it from the scanner.
  • Lift lid to its vertical position.
  • Pull lid straight up to remove it from the scanner.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Push the plastic opening tools into the crack between the top and the bottom of the chassis. Push the plastic opening tools into the crack between the top and the bottom of the chassis. Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
Agregar Comentario
After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis. Go all the way along the chassis until you can lift the upper lid. Go all the way along the chassis until you can lift the upper lid.
  • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
  • Go all the way along the chassis until you can lift the upper lid.
Agregar Comentario
Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid. Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid. Grab the ribbon cable and gently pull it out of its slot with your fingers.
  • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
  • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
  • Grab the ribbon cable and gently pull it out of its slot with your fingers.
  • The upper lid can now safely be removed from the bottom lid.
Agregar Comentario
Using a soft lint-free cloth clean the surface glass of dust, finger prints and other debris.
  • Using a soft lint-free cloth clean the surface glass of dust, finger prints and other debris.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 6-9, Regan Fall 2011 Miembro de Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 2,241
