Introducción
If sand, dirt or liquid has penetrated the outside covers of the camera, the function buttons might stick or cease to register. This guide shows you how to open the camera and clean the function keys.
Unscrew  a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver. There are 2 screws on the left side (when looking at the front of the camera). There are 3 screws on the bottom
  • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
  • There are 2 screws on the left side (when looking at the front of the camera).
  • There are 3 screws on the bottom
  • There is 1 screw on the right side
Agregar Comentario
Turn to the bottom of the camera.
  • Turn to the bottom of the camera.
  • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
Agregar Comentario
This is what the SD card/battery compartment looks like when opened.
  • This is what the SD card/battery compartment looks like when opened.
  • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
Agregar Comentario
Gently remove the front cover away from the camera body. Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  • Gently remove the front cover away from the camera body.
  • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
Agregar Comentario
The camera should look like this once the front cover is removed.
  • The camera should look like this once the front cover is removed.
Agregar Comentario
Start from the battery compartment and remove the back cover. Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body. Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  • Start from the battery compartment and remove the back cover.
  • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
  • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
Agregar Comentario
Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
Agregar Comentario
Turn to the back of the camera body. Rub the function keys and surrounding area with a clean cloth dipped in isopropyl alcohol.
  • Turn to the back of the camera body. Rub the function keys and surrounding area with a clean cloth dipped in isopropyl alcohol.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Shaelyn Thomas
Miembro Desde 19/04/11
287 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-6, Regan Spring 2011 Miembro de Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Miembros
8 Guías creadas
new Battery in side & massages is Battery low why?
Rupesh Jamsandekar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,543
