Partes
No se requieren partes.
Using a Philips screwdriver, remove the two screws on the top of the device, towards the back.
  • Using a Philips screwdriver, remove the two screws on the top of the device, towards the back.
Agregar Comentario
Remove the plastic cover by pulling up on the back and away from the faceplate. Remove the plastic cover by pulling up on the back and away from the faceplate.
  • Remove the plastic cover by pulling up on the back and away from the faceplate.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the faceplate by unclipping the latches on the bottom of the device. Once it's unlatched, pull the faceplate off. Once it's unlatched, pull the faceplate off.
  • Remove the faceplate by unclipping the latches on the bottom of the device.
  • Once it's unlatched, pull the faceplate off.
Agregar Comentario
Now that the device is open, you can check for any blown fuses that may need to be replaced.
  • Now that the device is open, you can check for any blown fuses that may need to be replaced.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Taryn
Miembro Desde 15/09/11
103 Reputación
4 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 752
