Saltar al contenido principal
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: paso 1, imagen 1 de 2 How to adjust Razor A steering column, How to adjust Razor A steering column: paso 1, imagen 2 de 2
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
  2. How to adjust Razor A steering column: paso 2, imagen 1 de 1
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
Linea de Meta
4 personas más completaron esta guía.
Jordyn
Miembro Desde 10/09/12
544 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 9-13, Amido Fall 2012 Miembro de Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Miembros
10 Guías creadas
8 comentarios
what move it with your hands? - didn't help
Heather McCasland - Contestar
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 -
Thanks you! Why doesn't the owners manual have this?
Jessica - Contestar
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Contestar
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 55
Ultimos 30 días: 183
Todo El Tiempo: 40,870
