Introducción
MirageOS is one of the most popular programs for the TI-84, as it is the OS that allows you to play numerous different types of games. However, it is not compatible with the TI-NSpire; at least not without some tweaks.
Herramientas
Partes
No se requieren partes.
Download the latest version of MirageOS and the latest version of MOSPATCH onto your computer. And if you do not already have it, the TI-NSpire connectivity software.
  • Download the latest version of MirageOS and the latest version of MOSPATCH onto your computer.
  • And if you do not already have it, the TI-NSpire connectivity software.
  • Save the files in a place you can access easily, preferably the desktop.
Agregar Comentario
Connect your TI-NSpire to your computer using the TI Calculator Link Cable.
  • Connect your TI-NSpire to your computer using the TI Calculator Link Cable.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Open TI Connect and double click "TI DeviceExplorer." A new window named Device Explorer will open.
  • Open TI Connect and double click "TI DeviceExplorer."
  • A new window named Device Explorer will open.
Agregar Comentario
Highlight the files mospatch.zip and mirageos.zip and drag them into the DeviceExplorer window. Highlight the files mospatch.zip and mirageos.zip and drag them into the DeviceExplorer window.
  • Highlight the files mospatch.zip and mirageos.zip and drag them into the DeviceExplorer window.
Agregar Comentario
Now on your calculator, bring up the catalog by pressing  2nd + 0 (catalog). Press the down arrow key to scroll down to the "Asm(" function (the last item) and press  "ENTER". Press PRGM, select MOSPATCH using the arrow keys, and press "ENTER".
  • Now on your calculator, bring up the catalog by pressing 2nd + 0 (catalog).
  • Press the down arrow key to scroll down to the "Asm(" function (the last item) and press "ENTER".
  • Press PRGM, select MOSPATCH using the arrow keys, and press "ENTER".
Agregar Comentario
The calculator should now display "Asm(prgmMOSPATCH". Press "ENTER". The calculator will display "DONE" indicating that you can now run MirageOS on your TI-NSpire!
  • The calculator should now display "Asm(prgmMOSPATCH".
  • Press "ENTER". The calculator will display "DONE" indicating that you can now run MirageOS on your TI-NSpire!
Agregar Comentario
Conclusión
Now that you have MirageOS running on your TI-NSpire, download some games and try them out! http://www.ticalc.org/pub/83plus/asm/gam...
John Baek
Miembro Desde 27/09/12
19 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-52, Forte Fall 2012 Miembro de Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Miembros
11 Guías creadas
show an example of running a game. and is the 84 keypad required?
trogfield - Contestar
it did not work for me can you help me fix that problem because ive been progaming my own and it did not work so can you find another way because im a big fan of your work it helps me alot
David Fife - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 12
Todo El Tiempo: 1,641
