Introducción
Have you ever had sticky keys or a defective keyboard for your LG Neon II? If the answer is yes, then it is most likely because of your keyboard being too dirty. In this simple guide, you can follow 7 steps to help solve your problem and make your keyboard easier to use.
To gain access to the phone’s speaker, grip the phone firmly in an inverted position with the back of the unit facing up and the LG insignia positioned away from you.
  • To gain access to the phone’s speaker, grip the phone firmly in an inverted position with the back of the unit facing up and the LG insignia positioned away from you.
  • Using both hands as support, use your thumbs to gently guide the rear housing away and in the direction of the arrow.
Agregar Comentario
After removing the phone’s back-panel, securely cushion the front of the phone on a soft surface such as a cloth or your hand.
  • After removing the phone’s back-panel, securely cushion the front of the phone on a soft surface such as a cloth or your hand.
  • Gently insert a spudger under the lip of the battery, preferably the lip away from the camera eye.
  • Gently pry the battery out of its seated position.
Agregar Comentario
To separate the button board/circuit module from the phone main frame, firmly, but gently, unscrew (counter-clockwise) the seven outside 4 mm screws along the rear outside rim of the main body.
  • To separate the button board/circuit module from the phone main frame, firmly, but gently, unscrew (counter-clockwise) the seven outside 4 mm screws along the rear outside rim of the main body.
  • Hold the phone securely.
  • Be sure to use the appropriate Philips #0 screw driver for the job. Not using the appropriate tool could damage the mounting screws.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate the lifted portion of plastic on the bottom end of the phone near the charger.
  • Locate the lifted portion of plastic on the bottom end of the phone near the charger.
  • Slide the plastic opening tool underneath this lip, and gently pry the black plastic cover off.
  • Use the appropriate plastic pry tool to avoid circuit board damage.
  • There are three buttons around the outside of the phone that will fall out when you remove the plastic cover.
Agregar Comentario
Loosen the two captive screws on the metal plate near the center of the phone using the Phillips #0 Screwdriver.
  • Loosen the two captive screws on the metal plate near the center of the phone using the Phillips #0 Screwdriver.
  • The screws will remain captive in the metal plate—do not attempt to remove them after they're loosened.
Agregar Comentario
Using the plastic opening tool, gently pry the circuit board from the phone. You may need to pry the circuit board in multiple locations to fully loosen it from the phone.
  • Using the plastic opening tool, gently pry the circuit board from the phone.
  • You may need to pry the circuit board in multiple locations to fully loosen it from the phone.
  • The underside of the circuit board is attached to the phone by some black tape. You will not be able to fully remove the circuit board, but you will be able to access the keyboard buttons located on the underside of the circuit board.
  • The partially separated circuit board may be attached to the main button area by factory adhesive/tape. If so, use a soft padded surface to rest the mother board on. Your work area will still be accessible without separating the two units.
Agregar Comentario
Using a brush or a soft cloth, gently clean the keyboard keys of any debree or contaminants.
  • Using a brush or a soft cloth, gently clean the keyboard keys of any debree or contaminants.
  • Using a brush or soft cloth, gently clean the silver keyboard buttons.
Agregar Comentario
Conclusión
To reassemble your device, follow these steps in reverse order.
Nathan
Miembro Desde 26/09/12
15 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 1-6, Propen Fall 2012 Miembro de Cal Poly, Team 1-6, Propen Fall 2012
CPSU-PROPEN-F12S1G6
3 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 345
