Saltar al contenido principal
How to Bind a Book Spine
Qué necesitas
  1. How to Bind a Book Spine, How to Bind a Book Spine: paso 1, imagen 1 de 1
    • First, grab the book you would like to fix.
  2. How to Bind a Book Spine: paso 2, imagen 1 de 1
    • Then, open the book to where you have the most access to the exposed inner spine.
  3. How to Bind a Book Spine: paso 3, imagen 1 de 1
    • Shake up the glue before removing the cap.
    • Then, test glue on a piece of paper before placing it on the spine of the book. It should be about the consistency of Elmer's glue.
  4. How to Bind a Book Spine: paso 4, imagen 1 de 1
    • Place the glue along the spine opposite of the cover. Make sure you are distributing glue evenly.
    • You may also choose to use a paint brush to make sure area is completely covered with glue.
    • Glue is runny; use with caution.
  5. How to Bind a Book Spine: paso 5, imagen 1 de 1
    • After placing the glue, wrap the cover tightly around the book.
    • Firmly drag your fingers down the spine of the book to avoid any air pockets.
    • Remove any excess glue with a tissue.
    • For the demonstration we held the book as shown. You may also choose to place something on top of the book, such as a paperweight or another book, and let it sit for 30 to 40 minutes.
  6. How to Bind a Book Spine: paso 6, imagen 1 de 1
    • After the glue is dry, you should be able to lightly tug on the pages without any movement.
    • If movement occurs then allow the glue an additional 10 to 15 minutes to dry. Once dry, you've completed your book repair.
Conclusión
2 personas más completaron esta guía.
Britne Misner
Miembro Desde 09/30/16
149 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 79
Todo El Tiempo: 1,247
