remove the three Phillips screws under the fan closest to the video ports of the card
  • remove the three Phillips screws under the fan closest to the video ports of the card
Agregar Comentario
Lift the fan out(will be attached to a small cord but gets out of the way well)  and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
  • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
Agregar Comentario
Reassemble and re-install the card into your computer. It should stop the vibration.
  • Reassemble and re-install the card into your computer. It should stop the vibration.
Agregar Comentario
Conclusión
8 personas más completaron esta guía.
Matthew Johnson
Miembro Desde 07/04/12
392 Reputación
2 Guías creadas
Can you post a picture showing how its fit in the fins?
Gustavo Horta - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 28
Todo El Tiempo: 7,084
