Introducción
Use this guide to replace the Motherboard.
Remove the outer screen cover by releasing  the top clip from the main body of the device. Remove the outer screen cover by releasing  the top clip from the main body of the device.
  • Remove the outer screen cover by releasing the top clip from the main body of the device.
Agregar Comentario
Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device.
  • Pull out the stylus from the top right corner of the device.
Agregar Comentario
Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device.
  • Slide the memory cartridge cover up and off the device.
Agregar Comentario
Remove the battery cover by releasing the clip from the main body of the device. Remove the battery cover by releasing the clip from the main body of the device.
  • Remove the battery cover by releasing the clip from the main body of the device.
Agregar Comentario
Remove the batteries from the device.
  • Remove the batteries from the device.
Agregar Comentario
Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
  • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
  • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
Agregar Comentario
Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device. Be careful while opening the casing as there is a flex strip connecting the two halves. Be careful while opening the casing as there is a flex strip connecting the two halves.
  • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
  • Be careful while opening the casing as there is a flex strip connecting the two halves.
Agregar Comentario
Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers.
  • Disconnect the flex strip from the motherboard with tweezers.
Agregar Comentario
Use tweezers to remove the power button from the back case.
  • Use tweezers to remove the power button from the back case.
Agregar Comentario
Disconnect the button pad by using the spudger to pry it off the motherboard. Remove the button pad. Remove the button pad.
  • Disconnect the button pad by using the spudger to pry it off the motherboard.
  • Remove the button pad.
Agregar Comentario
Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place. Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
  • Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
Agregar Comentario
Use the spudger to lift the motherboard from the case. Use the spudger to lift the motherboard from the case. Use the spudger to lift the motherboard from the case.
  • Use the spudger to lift the motherboard from the case.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 1-2, Regan SU 2012 Miembro de Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 695
