Saltar al contenido principal
Hair Dryer Fan/ Motor Assembly Replacement
Qué necesitas
  1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: paso 1, imagen 1 de 2 Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: paso 1, imagen 2 de 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Fan/ Motor Assembly Replacement, Grating: paso 2, imagen 1 de 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Fan/ Motor Assembly Replacement: paso 3, imagen 1 de 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Fan/ Motor Assembly Replacement: paso 4, imagen 1 de 1
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: paso 5, imagen 1 de 1
    • Locate the screws on the handle and remove with a Phillips screwdriver.
  6. Hair Dryer Fan/ Motor Assembly Replacement: paso 6, imagen 1 de 1
    • Carefully separate the plastic case with the Plastic Opening Tool.
  7. Hair Dryer Fan/ Motor Assembly Replacement: paso 7, imagen 1 de 1
    • After removing the plastic case, locate the fan towards the back of the hair dryer.
  8. Hair Dryer Fan/ Motor Assembly Replacement: paso 8, imagen 1 de 1
    • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
  9. Hair Dryer Fan/ Motor Assembly Replacement: paso 9, imagen 1 de 1
    • Remove the screws holding the motor to the casing using a Phillips screwdriver.
    • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
  10. Hair Dryer Fan/ Motor Assembly Replacement: paso 10, imagen 1 de 1
    • Isolate the fan from the rest of the dryer.
    • Remove the screws holding the motor in place. Replace with the new component.
  11. Hair Dryer Fan/ Motor Assembly Replacement: paso 11, imagen 1 de 1
    • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
    • Soldering Skills
Conclusión
2 personas más completaron esta guía.
Mitch
Miembro Desde 10/04/12
34 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 24-29, Regan Fall 2012 Miembro de Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 26
Ultimos 30 días: 100
Todo El Tiempo: 15,937
