Saltar al contenido principal
HTC Wizard 200 Keyboard Slider Replacement
Qué necesitas
  1. HTC Wizard 200 Keyboard Slider Replacement, Battery: paso 1, imagen 1 de 2 HTC Wizard 200 Keyboard Slider Replacement, Battery: paso 1, imagen 2 de 2
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Keyboard Slider Replacement, Back Panel: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Spudger
    $3.99
    Comprar
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Keyboard Slider Replacement: paso 3, imagen 1 de 2 HTC Wizard 200 Keyboard Slider Replacement: paso 3, imagen 2 de 2
    Spudger
    $3.99
    Comprar
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Keyboard Slider Replacement: paso 4, imagen 1 de 2 HTC Wizard 200 Keyboard Slider Replacement: paso 4, imagen 2 de 2
    T5 Torx Screwdriver
    $5.49
    Comprar
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Keyboard Slider Replacement: paso 5, imagen 1 de 3 HTC Wizard 200 Keyboard Slider Replacement: paso 5, imagen 2 de 3 HTC Wizard 200 Keyboard Slider Replacement: paso 5, imagen 3 de 3
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Keyboard Slider Replacement: paso 6, imagen 1 de 2 HTC Wizard 200 Keyboard Slider Replacement: paso 6, imagen 2 de 2
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Keyboard Slider Replacement, Motherboard: paso 7, imagen 1 de 1
    Spudger
    $3.99
    Comprar
    • Use the spudger to pry the camera off.
  8. HTC Wizard 200 Keyboard Slider Replacement: paso 8, imagen 1 de 2 HTC Wizard 200 Keyboard Slider Replacement: paso 8, imagen 2 de 2
    Comprar
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  9. HTC Wizard 200 Keyboard Slider Replacement: paso 9, imagen 1 de 1
    • Slide the keyboard into the open position.
  10. HTC Wizard 200 Keyboard Slider Replacement: paso 10, imagen 1 de 2 HTC Wizard 200 Keyboard Slider Replacement: paso 10, imagen 2 de 2
    Spudger
    $3.99
    Comprar
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  11. HTC Wizard 200 Keyboard Slider Replacement: paso 11, imagen 1 de 2 HTC Wizard 200 Keyboard Slider Replacement: paso 11, imagen 2 de 2
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
  12. HTC Wizard 200 Keyboard Slider Replacement, Keyboard Slider: paso 12, imagen 1 de 3 HTC Wizard 200 Keyboard Slider Replacement, Keyboard Slider: paso 12, imagen 2 de 3 HTC Wizard 200 Keyboard Slider Replacement, Keyboard Slider: paso 12, imagen 3 de 3
    T5 Torx Screwdriver
    $5.49
    Comprar
    • Remove the four 5mm screws with the T5 Torx screwdriver.
    • Remove the keyboard slider from the main body.
Conclusión
Una persona más ha completado esta guía.
Kyle Champ
Miembro Desde 10/03/11
225 Reputación
12 Guías creadas
Equipo
Cal Poly, Team 20-27, Maness Fall 2011 Miembro de Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Miembros
24 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 925
