Introducción
This guide will display how to remove and install the back panel of the HTC Wizard 200.
Remove the back case with your fingernail to expose the battery. (Not shown in picture) Pull the black tab to remove the battery.
  • Remove the back case with your fingernail to expose the battery. (Not shown in picture)
  • Pull the black tab to remove the battery.
Agregar Comentario
Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
  • Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
Agregar Comentario
Work the spudger around the edge of the camera cover to release the clips. Work the spudger around the edge of the camera cover to release the clips.
  • Work the spudger around the edge of the camera cover to release the clips.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
  • Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
  • There is a screw under the "void" sticker.
Agregar Comentario
Device rotated 180 degrees. Insert the flat end of a spudger into the crack between the front and rear cover.
  • Device rotated 180 degrees.
  • Insert the flat end of a spudger into the crack between the front and rear cover.
  • Once you have enough of a gap to fit a plastic opening tool into it, use the opening tool to release the clips.
Agregar Comentario
Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge. Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
  • Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
Agregar Comentario
Pull off the back case panel. Pull off the back case panel.
  • Pull off the back case panel.
Agregar Comentario
Conclusión
Kyle Champ
Miembro Desde 03/10/11
204 Reputación
12 Guías creadas
Equipo
Cal Poly, Team 20-27, Maness Fall 2011 Miembro de Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 996
