Introducción
Make sure you complete previous guide.
Power the phone off. Use your thumb to gently press downward and away from the camera to remove the battery cover.
  • Power the phone off.
  • Use your thumb to gently press downward and away from the camera to remove the battery cover.
Agregar Comentario
Pull on the plastic tab to release the battery. Pull on the plastic tab to release the battery.
  • Pull on the plastic tab to release the battery.
Agregar Comentario
Use a plastic opening tool to remove the camera cover. Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
  • Use a plastic opening tool to remove the camera cover.
  • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
  • Lift the camera cover off of the phone.
Agregar Comentario
Remove the stylus from the phone.
  • Remove the stylus from the phone.
  • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
  • One of the screws might be under a sticker, which will void your warranty.
Agregar Comentario
Be Careful! Do not insert the spudger in between the keyboard and screen.  This could break the keyboard off the phone. If your phone contains a memory card, you may want to remove it before proceeding with this step. Insert spudger in the bottom corner as seen in the picture.  Carefully slide the spudger from the bottom towards the top as seen in the second picture.
  • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
  • If your phone contains a memory card, you may want to remove it before proceeding with this step.
  • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
  • Lift the back case off completely.
  • The speakers might be dangling and unsecured.
Agregar Comentario
Grip the speaker connector with your thumb and finger and gently pull up. Repeat for 2nd speaker.
  • Grip the speaker connector with your thumb and finger and gently pull up.
  • Repeat for 2nd speaker.
Agregar Comentario
Conclusión
Taylor Stone
Miembro Desde 06/10/11
45 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 20-28, Maness Fall 2011 Miembro de Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 490
