Introducción
This guide will teach you how to take apart your phone so that you can remove/replace the screen.
Power the phone off. Use your thumb to gently press downward and away from the camera to remove the battery cover.
  • Power the phone off.
  • Use your thumb to gently press downward and away from the camera to remove the battery cover.
Agregar Comentario
Pull on the plastic tab to release the battery. Pull on the plastic tab to release the battery.
  • Pull on the plastic tab to release the battery.
Agregar Comentario
Use a plastic opening tool to remove the camera cover. Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
  • Use a plastic opening tool to remove the camera cover.
  • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
  • Lift the camera cover off of the phone.
Agregar Comentario
Remove the stylus from the phone.
  • Remove the stylus from the phone.
  • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
  • One of the screws might be under a sticker, which will void your warranty.
Agregar Comentario
Be Careful! Do not insert the spudger in between the keyboard and screen.  This could break the keyboard off the phone. If your phone contains a memory card, you may want to remove it before proceeding with this step. Insert spudger in the bottom corner as seen in the picture.  Carefully slide the spudger from the bottom towards the top as seen in the second picture.
  • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
  • If your phone contains a memory card, you may want to remove it before proceeding with this step.
  • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
  • Lift the back case off completely.
  • The speakers might be dangling and unsecured.
Agregar Comentario
Grip the speaker connector with your thumb and finger and gently pull up. Repeat for 2nd speaker.
  • Grip the speaker connector with your thumb and finger and gently pull up.
  • Repeat for 2nd speaker.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate the camera and pry off with the plastic opening tool or spudger.
  • Locate the camera and pry off with the plastic opening tool or spudger.
Agregar Comentario
Remove the 3.4 mm black screw with the Phillips #000 screwdriver.
  • Remove the 3.4 mm black screw with the Phillips #000 screwdriver.
Agregar Comentario
Remove the plastic tape to reveal the connector. Use your finger or plastic opening tool to flip the connector and release the cable.
  • Remove the plastic tape to reveal the connector.
  • Use your finger or plastic opening tool to flip the connector and release the cable.
Agregar Comentario
Use the plastic opening tool to carefully lift the motherboard off one corner at a time. Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
  • Use the plastic opening tool to carefully lift the motherboard off one corner at a time.
  • Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
  • If the motherboard is not easily removed by pulling, then lift one side of the motherboard until you can see the attached cable. Then use the plastic opening tool to detach the cable from the motherboard.
Agregar Comentario
Using the Phillips Screwdriver #000 remove the four 3.3 mm screws. Carefully lift the keyboard from the plastic plate by allowing the ribbon cable to slip through the opening of the plastic plate.
  • Using the Phillips Screwdriver #000 remove the four 3.3 mm screws.
  • Carefully lift the keyboard from the plastic plate by allowing the ribbon cable to slip through the opening of the plastic plate.
Agregar Comentario
Use the Phillips Screwdriver #000 to remove the four 3.8 mm screws from the back of the screen.
  • Use the Phillips Screwdriver #000 to remove the four 3.8 mm screws from the back of the screen.
Agregar Comentario
Insert the spudger between the panel and the case. Gently pry off the panel by rotating or wiggling the spudger back and forth. Lift the panel off while allowing the ribbon to slip through the opening.
  • Insert the spudger between the panel and the case.
  • Gently pry off the panel by rotating or wiggling the spudger back and forth.
  • Lift the panel off while allowing the ribbon to slip through the opening.
Agregar Comentario
Remove the four 2.9 mm screws with the Phillips Screwdriver #000. Use your fingers to separate the screen assembly from the front panel. Use your fingers to separate the screen assembly from the front panel.
  • Remove the four 2.9 mm screws with the Phillips Screwdriver #000.
  • Use your fingers to separate the screen assembly from the front panel.
Agregar Comentario
Insert the spudger between the green panel and the screen itself. Gently wiggle the spudger to pry them apart.
  • Insert the spudger between the green panel and the screen itself.
  • Gently wiggle the spudger to pry them apart.
Agregar Comentario
Remove the tape. Locate the connecting ribbon. Using the spudger or your thumb and finger, flip the switch up and disconnect the ribbon.
  • Remove the tape.
  • Locate the connecting ribbon.
  • Using the spudger or your thumb and finger, flip the switch up and disconnect the ribbon.
  • Lift off the panel from the screen.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Taylor Stone
Miembro Desde 06/10/11
45 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 20-28, Maness Fall 2011 Miembro de Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 861
