Introducción
Building upon basic teardown guides, this guide will allow you to replace the camera inside your phone in about 20 minutes.
Remove the back cover (not pictured) to your phone. Place it aside somewhere you won't lose it.
  • Remove the back cover (not pictured) to your phone. Place it aside somewhere you won't lose it.
Agregar Comentario
To begin removing the battery, place your thumb beneath the tab (outlined in red here) and begin to lift. Pinching the battery, lift up at an angle from the bottom of the phone.
  • To begin removing the battery, place your thumb beneath the tab (outlined in red here) and begin to lift.
  • Pinching the battery, lift up at an angle from the bottom of the phone.
Agregar Comentario
Place the battery in a container off to the side. If you do this for every step beyond this point, you will keep better track of your parts and make reassembling the device far easier when you get around to it.
  • Place the battery in a container off to the side. If you do this for every step beyond this point, you will keep better track of your parts and make reassembling the device far easier when you get around to it.
  • It might not be necessary, but we recommend using an anti-static bracelet or anti-static mat from this point on. Any charge on your finger tips may cause harm to the device.
Agregar Comentario
Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro. Place your screws in a bag labeled with where they came from, what screwdriver you used, and the order in which you removed them. For example, this bag would say "Rear casing. T6. #1." Place your screws in a bag labeled with where they came from, what screwdriver you used, and the order in which you removed them. For example, this bag would say "Rear casing. T6. #1."
  • Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro.
  • Place your screws in a bag labeled with where they came from, what screwdriver you used, and the order in which you removed them. For example, this bag would say "Rear casing. T6. #1."
Agregar Comentario
Next, remove the casing that covers the camera and motherboard. To do this, place your thumbnail in any of the grooves along either side and pry it open. To do this, place your thumbnail in any of the grooves along either side and pry it open.
  • Next, remove the casing that covers the camera and motherboard.
  • To do this, place your thumbnail in any of the grooves along either side and pry it open.
Agregar Comentario
Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown. Careful! The ribbon connecting the keyboard to the motherboard will still connect the two halves of the phone when you separate them. Be sure to take your time and move slowly to avoid damage to the cable.
  • Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown.
  • Careful! The ribbon connecting the keyboard to the motherboard will still connect the two halves of the phone when you separate them. Be sure to take your time and move slowly to avoid damage to the cable.
Agregar Comentario
Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard. Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard. Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
  • Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
Agregar Comentario
Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment. Remove the ribbon covering the battery compartment by pinching it at the base and lifting. Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
  • Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment.
  • Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
Agregar Comentario
The camera is only held in by one connection to the motherboard and some tape. Remove its connection to motherboard in the same way that you've removed such connections in the past.
  • The camera is only held in by one connection to the motherboard and some tape.
  • Remove its connection to motherboard in the same way that you've removed such connections in the past.
Agregar Comentario
Peel the tape holding it in place. After that it will be free to remove and replace as necessary.
  • Peel the tape holding it in place.
  • After that it will be free to remove and replace as necessary.
Agregar Comentario
Conclusión
Jack Bowen
Miembro Desde 09/04/11
79 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 20-67, Walters Spring 2011 Miembro de Cal Poly, Team 20-67, Walters Spring 2011
CPSU-WALTERS-S11S20G67
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,286
