Introducción
Sometime as part of your device malfunctioned and you would like to replace the part by yourself, this is where this guide come in handy.
Partes
No se requieren partes.
Gently press on back plate, push toward camera direction. Gently press on back plate, push toward camera direction.
  • Gently press on back plate, push toward camera direction.
Agregar Comentario
Use finger to lift up an edge of battery. Use finger to lift up an edge of battery.
  • Use finger to lift up an edge of battery.
Agregar Comentario
Remove 4 screws circled in red using T6 screw driver.
  • Remove 4 screws circled in red using T6 screw driver.
Agregar Comentario
Lift plastic cover near Memory card slot. Lift plastic cover near Memory card slot.
  • Lift plastic cover near Memory card slot.
Agregar Comentario
Remove two Phillips #00 screws from the backside of the screen.
  • Remove two Phillips #00 screws from the backside of the screen.
Agregar Comentario
Insert a spudger or plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
  • Insert a spudger or plastic opening tool into the seam on the side of the phone.
  • Gently pry apart the two halves of the phone.
  • Work your way around the phone until the two halves separate.
Agregar Comentario
Gently unplug connectors marked with blue rectangle. Remove screws circled in red with 00 Phillip screw driver.
  • Gently unplug connectors marked with blue rectangle.
  • Remove screws circled in red with 00 Phillip screw driver.
Which screws in red? There aren't any.
Calion - Contestar
They are marked up in red in the second picture.
Jake Devincenzi -
Gently lift logic board using plastic opener tool. Be aware of antenna
  • Gently lift logic board using plastic opener tool.
  • Be aware of antenna
Agregar Comentario
Remove 4 screws circled in red using 00 Phillip screw driver. Remove 4 screws circled in red using 00 Phillip screw driver.
  • Remove 4 screws circled in red using 00 Phillip screw driver.
Agregar Comentario
Lift back plate of screen using finger or plastic opener tool Lift back plate of screen using finger or plastic opener tool
  • Lift back plate of screen using finger or plastic opener tool
Agregar Comentario
Gently lift conncetors marked with blue rectangles.
  • Gently lift conncetors marked with blue rectangles.
  • Remove 4 screws marked in red circles using 00 philip screw driver
Agregar Comentario
Lift front keyboard, remove screws circled in red with 00 philip screw driver
  • Lift front keyboard, remove screws circled in red with 00 philip screw driver
Agregar Comentario
With  front keyboard removed, gently lift screen with plastic opener tool. With  front keyboard removed, gently lift screen with plastic opener tool. With  front keyboard removed, gently lift screen with plastic opener tool.
  • With front keyboard removed, gently lift screen with plastic opener tool.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Zhaowei Zhang
Miembro Desde 28/04/11
112 Reputación
4 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 3,378
