Introducción
Warning: Always be sure you are grounded whenever handling any of the circuit or logic boards.
Remove the back panel by sliding it up.
  • Remove the back panel by sliding it up.
Agregar Comentario
Remove the battery.
  • Remove the battery.
Agregar Comentario
Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
  • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
Agregar Comentario
Use the plastic opening tool to remove the front panel from the phone. Unplug the front button cable from the inside of the phone.
  • Use the plastic opening tool to remove the front panel from the phone.
  • Unplug the front button cable from the inside of the phone.
Agregar Comentario
Remove the 2 philips-head screws on the back of the front panel using the PH00 screwdriver.
  • Remove the 2 philips-head screws on the back of the front panel using the PH00 screwdriver.
Agregar Comentario
Remove the small circuit board by gently pushing on the center button on the front of the phone.
  • Remove the small circuit board by gently pushing on the center button on the front of the phone.
Agregar Comentario
Remove the buttons by pushing on them from the front side of the phone.
  • Remove the buttons by pushing on them from the front side of the phone.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Andrew Brooks
Miembro Desde 13/04/11
101 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-12, Regan Spring 2011 Miembro de Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 2,740
