Introducción
Use this guide to replace a speaker that no longer outputs sound.
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
  • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
  • Gently pry up on the rear panel around the edges until it is loose.
Agregar Comentario
Lift and remove the rear panel.
  • Lift and remove the rear panel.
Agregar Comentario
Using the plastic opening tool, lift up the battery from the bottom near the kickstand. Remove the battery from the inner frame.
  • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
  • Remove the battery from the inner frame.
Agregar Comentario
Remove the six Phillips screws from the perimeter of the rear frame.
  • Remove the six Phillips screws from the perimeter of the rear frame.
  • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
Agregar Comentario
Insert the plastic opening tool into the bottom of the phone underneath the soft keys. Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
  • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
  • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
  • Remove the plastic cover.
  • The plastic cover will have adhesive on it making it difficult to remove.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two Phillips screws where the plastic cover was.
  • Remove the two Phillips screws where the plastic cover was.
Agregar Comentario
Insert the plastic opening tool in between the screen and the frame on the side of the phone. Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
  • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
  • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
  • Do the same for the opposite side of the phone.
Agregar Comentario
Carefully separate the screen and phone from the rear frame, starting from the bottom. Gently pull down on the phone and screen to fully separate it from the rear frame. Gently pull down on the phone and screen to fully separate it from the rear frame.
  • Carefully separate the screen and phone from the rear frame, starting from the bottom.
  • Gently pull down on the phone and screen to fully separate it from the rear frame.
Agregar Comentario
Remove the two Phillips screws securing rear inner frame to device.
  • Remove the two Phillips screws securing rear inner frame to device.
Agregar Comentario
Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
  • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
Agregar Comentario
Remove the rear inner frame from the rest of the device. Remove the rear inner frame from the rest of the device.
  • Remove the rear inner frame from the rest of the device.
Agregar Comentario
Flip over rear inner frame.
  • Flip over rear inner frame.
Agregar Comentario
Pry out speaker with plastic opening tools. You have now removed the speaker.
  • Pry out speaker with plastic opening tools.
  • You have now removed the speaker.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 19-45, Regan Winter 2013 Miembro de Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 514
