Saltar al contenido principal
HTC SMT 6175 Keyboard Replacement
Qué necesitas
  1. HTC SMT 6175 Keyboard Replacement, Back Case: paso 1, imagen 1 de 1
    • First, flip the phone over so that the back is facing upwards.
  2. HTC SMT 6175 Keyboard Replacement: paso 2, imagen 1 de 2 HTC SMT 6175 Keyboard Replacement: paso 2, imagen 2 de 2
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. HTC SMT 6175 Keyboard Replacement, Battery: paso 3, imagen 1 de 2 HTC SMT 6175 Keyboard Replacement, Battery: paso 3, imagen 2 de 2
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. HTC SMT 6175 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 HTC SMT 6175 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • To remove the back casing inside the phone, remove the six screws around the perimeter.
  5. HTC SMT 6175 Keyboard Replacement: paso 5, imagen 1 de 2 HTC SMT 6175 Keyboard Replacement: paso 5, imagen 2 de 2
    • Carefully pull off the back casing.
    • This step may be difficult. Start pulling the back out from the front shell. As it starts to lift up, move the phone side-to-side until the whole back is free.
  6. HTC SMT 6175 Keyboard Replacement: paso 6, imagen 1 de 2 HTC SMT 6175 Keyboard Replacement: paso 6, imagen 2 de 2
    • Remove the top screw.
    • Be CAREFUL, because the LCD screen is attached to the front side of the motherboard by a flexible ribbon cable.
  7. HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: paso 7, imagen 1 de 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: paso 7, imagen 2 de 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: paso 7, imagen 3 de 3
    • Pull the plastic keyboard away from the front case.
  8. HTC SMT 6175 Keyboard Replacement, Navigation Keys: paso 8, imagen 1 de 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: paso 8, imagen 2 de 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: paso 8, imagen 3 de 3
    • To remove the navigation keys on the front of the phone, remove the four screws securing the navigation keys using a Phillips screwdriver.
    • Remove the navigation keys from the front of the phone.
    • They should pop out as a unit.
Conclusión
Luke Plewa
Miembro Desde 04/22/11
116 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 25-29, Garner Spring 2011 Miembro de Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,665
