Saltar al contenido principal
HTC Ozone Keyboard Replacement
Qué necesitas
  1. HTC Ozone Keyboard Replacement, Rear Battery Cover: paso 1, imagen 1 de 1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Keyboard Replacement: paso 2, imagen 1 de 2 HTC Ozone Keyboard Replacement: paso 2, imagen 2 de 2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Keyboard Replacement, Battery: paso 3, imagen 1 de 3 HTC Ozone Keyboard Replacement, Battery: paso 3, imagen 2 de 3 HTC Ozone Keyboard Replacement, Battery: paso 3, imagen 3 de 3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Keyboard Replacement, Frame: paso 4, imagen 1 de 3 HTC Ozone Keyboard Replacement, Frame: paso 4, imagen 2 de 3 HTC Ozone Keyboard Replacement, Frame: paso 4, imagen 3 de 3
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Keyboard Replacement: paso 5, imagen 1 de 3 HTC Ozone Keyboard Replacement: paso 5, imagen 2 de 3 HTC Ozone Keyboard Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Keyboard Replacement, Motherboard: paso 6, imagen 1 de 2 HTC Ozone Keyboard Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Keyboard Replacement: paso 7, imagen 1 de 2 HTC Ozone Keyboard Replacement: paso 7, imagen 2 de 2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Keyboard Replacement: paso 8, imagen 1 de 3 HTC Ozone Keyboard Replacement: paso 8, imagen 2 de 3 HTC Ozone Keyboard Replacement: paso 8, imagen 3 de 3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
  9. HTC Ozone Keyboard Replacement, LCD Display: paso 9, imagen 1 de 2 HTC Ozone Keyboard Replacement, LCD Display: paso 9, imagen 2 de 2
    • Remove the gray tape securing the ribbon cable.
  10. HTC Ozone Keyboard Replacement: paso 10, imagen 1 de 1
    • Remove the yellow tape securing the connector lock.
  11. HTC Ozone Keyboard Replacement: paso 11, imagen 1 de 2 HTC Ozone Keyboard Replacement: paso 11, imagen 2 de 2
    • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
  12. HTC Ozone Keyboard Replacement: paso 12, imagen 1 de 1
    • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
  13. HTC Ozone Keyboard Replacement: paso 13, imagen 1 de 1
    • Lift the Motherboard away from the LCD display.
  14. HTC Ozone Keyboard Replacement, Keyboard: paso 14, imagen 1 de 2 HTC Ozone Keyboard Replacement, Keyboard: paso 14, imagen 2 de 2
    • Lift off main keyboard from front plastic case using plastic opening tool.
  15. HTC Ozone Keyboard Replacement: paso 15, imagen 1 de 2 HTC Ozone Keyboard Replacement: paso 15, imagen 2 de 2
    • Remove four Phillips #00 screws securing function keys.
  16. HTC Ozone Keyboard Replacement: paso 16, imagen 1 de 2 HTC Ozone Keyboard Replacement: paso 16, imagen 2 de 2
    • Pop keys out by pushing keys from back of the phone.
Conclusión
Una persona más ha completado esta guía.
Marco Jokada
Miembro Desde 04/28/11
247 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 1,782
